guztavo
#1 Posted : Wednesday, February 13, 2019 9:59:25 PM(UTC)
guztavo
Hi!
I want to know if NDI will work fine on this setup:
-Router TP-Link TL470+
-Switch TP-Link TL-SG108
The router only will be used to balance the load over the WANs connections (NDI sources and vMix will be connected to the switch).
So NDI will work? Or the router will down the speed of entire network?
Thanks in advance!
mjgraves
#2 Posted : Thursday, February 14, 2019 3:46:57 AM(UTC)
mjgraves
Will work fine as long as your WAN speed is less than 100 mbps.
The NDI traffic will never see the router. It will be limited to between ports on the switch.
