Systems
I9 9900k / z390 ultra
Joined: 12/7/2018(UTC) Posts: 6   Location: São Paulo
Could you guys help me with a pc for vmix? I9 9900k Gigabyte Aorus z390 ultra GTX 1060 16gb ddr4 26660 m2 for the system and two Blackmagic boards: decklink duo2 decklink quad 2
in this configuration the vmix works smoothly with 10 cameras entering and 2 leaving
If you are spending for all of this...why not put in more RAM? Small cost in this build. Also, I would prefer a 1070ti or 1080ti GPU, but have noticed that they are hard to get now. The 1060 needs as much RAM as possible. Otherwise should be OK.
1 x PCI Express x16 slot, running at x16 (PCIEX16) * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot. 1 x PCI Express x16 slot, running at x8 (PCIEX8) * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot operates at up to x8 mode. 1 x PCI Express x16 slot, running at x4 (PCIEX4) * The PCIEX4 slot shares bandwidth with the M2P connector. The PCIEX4 slot operates at up to x2 mode when a PCIe SSD is installed in the M2P connector
DeckLink Quad 2 8x HD-SDI IN/OUT PCI Express Slot (x8) DeckLink Duo 2 4x HD-SDI IN/OUT PCI Express Slot (x4)
Joined: 4/15/2018(UTC) Posts: 64  Location: Spain Thanks: 6 times Was thanked: 19 time(s) in 13 post(s)
For 10x cameras i recommend change to i9 7900x, because has more pcie Lanes.
Regards
Originally Posted by: JoseL  For 10x cameras i recommend change to i9 7900x, because has more pcie Lanes.
Regards
Really? I did not know about that, what motherboard would you recommend with 7900?
You can check vmix recommended systems, obsidian, i use gigabyte x299 gaming 7 and x299 designare ex. Designare has thunderbolt ports.
Regards
Jose.
Systems
