Rodrigo Rey
#1 Posted : Monday, February 11, 2019 7:39:50 AM(UTC)
Rodrigo Rey
Brazil
Could you guys help me with a pc for vmix?
I9 9900k
Gigabyte Aorus z390 ultra
GTX 1060
16gb ddr4 26660
m2 for the system
and two Blackmagic boards:
decklink duo2
decklink quad 2
in this configuration the vmix works smoothly with 10 cameras entering and 2 leaving
ask
#2 Posted : Monday, February 11, 2019 4:33:49 PM(UTC)
ask
If you are spending for all of this...why not put in more RAM? Small cost in this build. Also, I would prefer a 1070ti or 1080ti GPU, but have noticed that they are hard to get now. The 1060 needs as much RAM as possible. Otherwise should be OK.
1 x PCI Express x16 slot, running at x16 (PCIEX16)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot operates at up to x8 mode.
1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the M2P connector. The PCIEX4 slot operates at up to x2 mode when a PCIe SSD is installed in the M2P connector
DeckLink Quad 2
8x HD-SDI IN/OUT
PCI Express Slot (x8)
DeckLink Duo 2
4x HD-SDI IN/OUT
PCI Express Slot (x4)
JoseL
#3 Posted : Tuesday, February 12, 2019 3:26:55 PM(UTC)
JoseL
You have been a member since:: 4/15/2018(UTC)
Was thanked: 19 time(s) in 13 post(s)
For 10x cameras i recommend change to i9 7900x, because has more pcie Lanes.
Regards
Rodrigo Rey
#4 Posted : Tuesday, February 12, 2019 7:25:30 PM(UTC)
Rodrigo Rey
Brazil
Regards
Really? I did not know about that, what motherboard would you recommend with 7900?
JoseL
#5 Posted : Wednesday, February 13, 2019 1:01:33 AM(UTC)
JoseL
You can check vmix recommended systems, obsidian, i use gigabyte x299 gaming 7 and x299 designare ex. Designare has thunderbolt ports.
Regards
Jose.
