Hi. Is there anyway to integrate viber calls into vmix. For example taking video and audio from a Blackmagic Decklink Duo card and input both audio and video into the viber desktop app. Right now the video comes in fine but there's no option to input voice/audio into the viber desktop app. Here's a sample of the issueAny help or advice is appreciated. Thank you.
When routing audio between two software applications (viber & vMix) you need to use virtual audio cables. https://www.vb-audio.com/Cable/index.htmThey give you a virtual audio device. You can send sounds from vMix into the VBCable. Then select the VB-Cable as your device in viber (or whatever.)
