ameedmv
#1 Posted : Sunday, February 10, 2019 3:01:21 AM(UTC)
ameedmv
Maldives
Hi.
Is there anyway to integrate viber calls into vmix. For example taking video and audio from a Blackmagic Decklink Duo card and input both audio and video into the viber desktop app.
Right now the video comes in fine but there's no option to input voice/audio into the viber desktop app.
Here's a sample of the issue
Any help or advice is appreciated.
Thank you.
mjgraves
#2 Posted : Sunday, February 10, 2019 6:06:34 AM(UTC)
mjgraves
When routing audio between two software applications (viber & vMix) you need to use virtual audio cables.
https://www.vb-audio.com/Cable/index.htm
They give you a virtual audio device. You can send sounds from vMix into the VBCable. Then select the VB-Cable as your device in viber (or whatever.)
