Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi there
I'm trying to send an external output without audio. Here is the setup : my output is going through a BMD duo 2 SDI to a videoprojector in a room. The problem is that the audio is turned on volume loud on this projector, and when I run the external toggle on, I hear the audio of the program in the (bad) audio monitor of the projector.
How can I prevent that ?
Joined: 8/2/2013(UTC) Posts: 1,111   Location: Fairhope, Alabama USA Thanks: 604 times Was thanked: 205 time(s) in 171 post(s)
In vMix Settings --> External Output --> Audio Device --> select "None."
- Tom
Originally Posted by: sinc747  In vMix Settings --> External Output --> Audio Device --> select "None."
- Tom Hi Tom, Thanks for your response, but when I select a Device first, the "audio device" menu disappears...
