GT
Another bug possibly?
I may have found a bug, it seems when I have a graphic with animations, saved, used in vmix, if I later decide I'd rather not have animations, I edit it in GT, save it, reload the title in vMix. At this point the title is completely useless and shows nothing. I have to totally re-create the graphic from scratch if I want to change from animations to no animations.
IMO, if I change my mind and select "none" in the animation, and save it, it should work as if I never had them, not sure why it's behaving this way.
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
Can you upload the title that isn't working in vMix so we can see what is happening?
Thanks,
Martin vMix
GT
