rossif76
#1 Posted : Sunday, January 6, 2019 11:47:11 AM(UTC)
rossif76
No matter how I include cefbrowserinstance.exe (both versions of it) in my nvidia Control Panel, my control panel shows that cefbrowserinstance.exe when I open browser instances inside vMix are not using the 1070 GPU engine (even though the vMix application itself is using it). What do I have to do to force the browser instances to use the GPU?
- Frank
ask
#2 Posted : Sunday, January 6, 2019 12:16:23 PM(UTC)
ask
Was thanked: 144 time(s) in 131 post(s)
Try setting it through the nVidia Control Panel
rossif76
#3 Posted : Sunday, January 6, 2019 1:49:24 PM(UTC)
rossif76
I did (both versions of it). It's not forcing it through.
desmar
#4 Posted : Sunday, January 6, 2019 3:07:36 PM(UTC)
desmar
Canada
Was thanked: 62 time(s) in 45 post(s)
CEFBrowserInstance is run thru vMix and does not use GPU Acceleration natively from what I have read.
rossif76
#5 Posted : Monday, January 7, 2019 5:42:26 AM(UTC)
rossif76
That's a disappointing oversight, especially since each Chromium instance uses about 5-7% of my CPU. With 12 video streams at 720p in Browser windows, I end up maxed out.
