Joined: 2/9/2014(UTC) Posts: 14 Location: New York, New York
No matter how I include cefbrowserinstance.exe (both versions of it) in my nvidia Control Panel, my control panel shows that cefbrowserinstance.exe when I open browser instances inside vMix are not using the 1070 GPU engine (even though the vMix application itself is using it). What do I have to do to force the browser instances to use the GPU?
- Frank
Joined: 10/13/2012(UTC) Posts: 1,157  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
Try setting it through the nVidia Control Panel
Originally Posted by: ask  Try setting it through the nVidia Control Panel I did (both versions of it). It's not forcing it through.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
CEFBrowserInstance is run thru vMix and does not use GPU Acceleration natively from what I have read.
That's a disappointing oversight, especially since each Chromium instance uses about 5-7% of my CPU. With 12 video streams at 720p in Browser windows, I end up maxed out.
