macgiver76
#1 Posted : Sunday, January 6, 2019 5:00:50 AM(UTC)
macgiver76
Hi everyone, my structure is this:
Studio TV broadcasts to a rtmp server from Vmix;
TV station Receives the stream from the rtmp server and sends it to the SDI output with blackmagic.
Everything works well. If the transmission is disconnected, I have set the input with trigger "On Completion" - Fade - to another input. I would also do the opposite, that is, when you restore the link should return to play the input with the stream rtmp but I can not do it.
What am I doing wrong?
Thank you
leledt
#2 Posted : Monday, January 7, 2019 7:34:55 PM(UTC)
leledt
Italy
+1
Similar Topics
Merge/Input Trigger Errors causing me stress (General Discussion)
by edscanada 5/18/2022 2:15:01 AM(UTC)
What is the Maximum Input Trigger Delay Value (General Discussion)
by kismetgerald 1/18/2022 2:49:12 AM(UTC)
Virtual input trigger oncompletion not working (General Discussion)
by ProSonas 1/14/2019 11:11:32 PM(UTC)
PreviewInput Triggers not working correctly (General Discussion)
by DeeJay 10/19/2017 9:08:26 AM(UTC)
Switch to Input triggered from Motion Sensor (General Discussion)
by RoboST 2/6/2017 5:59:07 PM(UTC)
30 second limit on OverlayInput triggers? (General Discussion)
by jsandytn 11/15/2014 8:44:36 AM(UTC)
