NDI
Output to SDI Decklink
Joined: 1/1/2019(UTC) Posts: 8  Location: Port Huron Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
We are running NDO cameras into a Vmix based PC and outputting to the internet. We wish to send the program output to concourse TV's in outside our main auditorium area. We have a Decklink SDI card in the Vmix PC. Will we be able to send the program output through an internal PCI decklink SDI I/O that I can connect to concourse monitors? We would be sending the SDI into an SDI to HDMI converter that would hook to the TV's.
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
 1 user thanked ask for this useful post.
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
I don't have the hardware yet, but in the future I need two cloned program outputs (HDMI and SDI). Is it possible to send external output to a dual head graphics card and SDI out on a capture card simultaneous?
Or in other words, can I assign the SDI output of a capture card to each vMix output? (I have not decided yet which capture card I will buy)
Originally Posted by: Ronald555  Is it possible to send external output to a dual head graphics card and SDI out on a capture card simultaneous?
Yes...if you card supports both input and output. See the link in the post above.
NDI
