douglukas
#1 Posted : Thursday, January 3, 2019 1:05:40 PM(UTC)
douglukas
We are running NDO cameras into a Vmix based PC and outputting to the internet. We wish to send the program output to concourse TV's in outside our main auditorium area. We have a Decklink SDI card in the Vmix PC. Will we be able to send the program output through an internal PCI decklink SDI I/O that I can connect to concourse monitors? We would be sending the SDI into an SDI to HDMI converter that would hook to the TV's.
ask
#2 Posted : Thursday, January 3, 2019 2:34:44 PM(UTC)
ask
douglukas on 1/5/2019(UTC)
Ronald555
#3 Posted : Saturday, January 5, 2019 11:11:56 PM(UTC)
Ronald555
I don't have the hardware yet, but in the future I need two cloned program outputs (HDMI and SDI).
Is it possible to send external output to a dual head graphics card and SDI out on a capture card simultaneous?
Or in other words, can I assign the SDI output of a capture card to each vMix output?
(I have not decided yet which capture card I will buy)
ask
#4 Posted : Sunday, January 6, 2019 6:49:40 AM(UTC)
ask
Yes...if you card supports both input and output. See the link in the post above.
Ronald555 on 1/8/2019(UTC)
