I'm new to vMix and coming from OBS. There is a built in noise suppression in OBS that I'm using and completely forgot about this. What free options are available for vMix? I'm streaming for a non-profit and completely blown the budget and now suddenly looking at more costs for a plugin like NS1 noise suppressor. Thanks in advance for the help!
vMix has a builtin compressor, EQ, and Noise Gate effects.....check the manual https://www.vmix.com/help21/ just download and keep for reference....
Thanks for the link. The noise gate is somewhat helpful, but as soon as you start talking the background noise in the in audio and that background baseline noise isn't filtered out. I guess vMix doesn't have a free solution to NS1 Noise Suppressor plugin.
