Multicorder/Audio recording
Hello, I am the editor and tech guy for a gaming channel on Youtube. We use multicorder for gameplay videos and streams, because I love the possibility of scaling the sources independently in the editing but most importantly because it records the audio separately for later mixing. I know that it is not possible to record stand-alone audio inputs with multicorder, but I am wondering if there is a way to create a "dummy" video input and assign an audio input to this, to make it appear in the multicorder window. For example to record Discord audio as a separate source, so it can be mixed in editing later on. Since I have not found a way to record audio separately, we have to use a second laptop with Discord and OBS to record the voice chat.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Yes, you can, Select camera input, check off show legacy devices, select vMix video, then select audio device you want. This will create a video input with video bars with your selected audio.  Capture.PNG (4kb) downloaded 0 time(s).Originally Posted by: ebjorno  Hello, I am the editor and tech guy for a gaming channel on Youtube. We use multicorder for gameplay videos and streams, because I love the possibility of scaling the sources independently in the editing but most importantly because it records the audio separately for later mixing. I know that it is not possible to record stand-alone audio inputs with multicorder, but I am wondering if there is a way to create a "dummy" video input and assign an audio input to this, to make it appear in the multicorder window. For example to record Discord audio as a separate source, so it can be mixed in editing later on. Since I have not found a way to record audio separately, we have to use a second laptop with Discord and OBS to record the voice chat.
