Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
I am trying to write a script that does a telnet connection to a remote system
I need to define a variable as TCPClient but the type is not defined in the script editor
Essentially i need this: Imports System.IO Imports System.Net Imports System.Net.Sockets
Help please fine vMixer folks :)
Keith
Joined: 3/15/2018(UTC) Posts: 82  Thanks: 5 times Was thanked: 10 time(s) in 8 post(s)
Originally Posted by: smudge1977  I am trying to write a script that does a telnet connection to a remote system
Keith
please explain more what is needed , scripting where ? xamls ??
I would like to send TCP commands to a BlackMagic Video hub matrix from a vMix script
this should be just a telnet command to port 9990
I also want to be able to conteol Barco E2 which is also telnet on a custom port
I think i will end up instead doing it via a DLL that i load as a title as i then have the full vb blend enviroment available!
Keith
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Originally Posted by: smudge1977  I would like to send TCP commands to a BlackMagic Video hub matrix from a vMix script
Keith
This is a Very interesting project that I have been thinking about for a long time. Please keep us posted with your progress and details. Good Luck, Steve
Joined: 8/22/2013(UTC) Posts: 92  Location: Rochester, NY Was thanked: 13 time(s) in 9 post(s)
In case anyone else wants to send a tcp message to another client using vMix scripting, I just figured it out... Create a new script and add the following code. Be sure to change your destination IP address, port and the message you want to send Code:
Dim clientIP as String = "XX.XX.XX.XXX"
Dim clientPort as String = "XXXXX"
Dim message as String = "YOURMESSAGE"
Dim client As New System.Net.Sockets.TcpClient(clientIP, clientPort)
client.SendTimeout = 1000
client.ReceiveTimeout = 1000
' Translate the passed message into ASCII and store it as a Byte array.
Dim data As [Byte]() = System.Text.Encoding.ASCII.GetBytes(message)
' Get a client stream for reading and writing.
Dim stream As System.Net.Sockets.NetworkStream = client.GetStream()
' Send the message to the connected TcpServer.
stream.Write(data, 0, data.Length)
' Receive the TcpServer.response.
' Buffer to store the response bytes.
data = New [Byte](256) {}
If stream.CanRead Then
Dim myReadBuffer(1024) As Byte
Dim myCompleteMessage As System.Text.StringBuilder = New System.Text.StringBuilder
Dim numberOfBytesRead As Integer = 0
' Incoming message may be larger than the buffer size.
Do
Try
Threading.Thread.Sleep(100)
numberOfBytesRead = stream.Read(myReadBuffer, 0, myReadBuffer.Length)
myCompleteMessage.AppendFormat("{0}", System.Text.Encoding.ASCII.GetString(myReadBuffer, 0, numberOfBytesRead))
Catch ex As Exception
stream.Close()
client.Close()
Exit Sub
End Try
Loop While stream.DataAvailable
' Close everything.
stream.Close()
client.Close()
Exit Sub
Else
Exit Sub
End If
Smudge . . . you were close. Since there is no "Imports", you just have to use your classes explicitly. So for example, to set the output on a videohub: Code:
Dim clientPort as String = "9990"
Dim input as String = "1"
Dim output as String = "7"
Dim message as String = "VIDEO OUTPUT ROUTING:" & Environment.NewLine & output & " " & input & Environment.NewLine & Environment.NewLine
:-) -Brian TESN.US
 3 users thanked tesn for this useful post.
I'm trying to create a script using the code mentioned in this thread. I'm trying to send Telnet commands to a Vaddio Roboshot20 PTZ camera. I have successfully sent commands from command prompt and PowerShell, but I'm not having success in vMix. I think that my issue might be that there is a username and password that you have to enter before you can throw commands at the camera. This is what I've tried so far. Quote:Dim clientIP as String = "192.168.3.101" Dim clientPort as String = "23" Dim message as String = "admin" message = "password" message = "camera preset recall 1"
... I'm not much of a coder so my apologies for my noobiness.
Hi jthrup,
Did you find some solutions for your usecase? I've the same situation as you. I am looking to send telnet commands from vmix. I don't have to fill username or password. Only a command like "page 1000: read" with an ip and a port.
It works fine with powershell. But, the script above doesn't work for me either.
