smudge1977
#1 Posted : Thursday, November 8, 2018 10:00:14 AM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
I am trying to write a script that does a telnet connection to a remote system
I need to define a variable as TCPClient but the type is not defined in the script editor
Essentially i need this:
Imports System.IO
Imports System.Net
Imports System.Net.Sockets
Help please fine vMixer folks :)
Keith
marcyaghi1
#2 Posted : Thursday, November 8, 2018 4:39:53 PM(UTC)
marcyaghi1
Afganistan
Imports System.IO
Imports System.Net
Keith
please explain more what is needed , scripting where ? xamls ??
smudge1977
#3 Posted : Friday, November 9, 2018 9:41:46 PM(UTC)
smudge1977
I would like to send TCP commands to a BlackMagic Video hub matrix from a vMix script
this should be just a telnet command to port 9990
I also want to be able to conteol Barco E2 which is also telnet on a custom port
I think i will end up instead doing it via a DLL that i load as a title as i then have the full vb blend enviroment available!
Keith
stevespaw
#4 Posted : Saturday, November 10, 2018 12:29:16 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Keith
This is a Very interesting project that I have been thinking about for a long time.
Please keep us posted with your progress and details.
Good Luck,
Steve
tesn
#5 Posted : Thursday, December 27, 2018 12:59:55 AM(UTC)
tesn
Was thanked: 13 time(s) in 9 post(s)
In case anyone else wants to send a tcp message to another client using vMix scripting, I just figured it out...
Create a new script and add the following code. Be sure to change your destination IP address, port and the message you want to send
Code:
Dim clientIP as String = "XX.XX.XX.XXX"
Dim clientPort as String = "XXXXX"
Dim message as String = "YOURMESSAGE"
Dim client As New System.Net.Sockets.TcpClient(clientIP, clientPort)
client.SendTimeout = 1000
client.ReceiveTimeout = 1000
' Translate the passed message into ASCII and store it as a Byte array.
Dim data As [Byte]() = System.Text.Encoding.ASCII.GetBytes(message)
' Get a client stream for reading and writing.
Dim stream As System.Net.Sockets.NetworkStream = client.GetStream()
' Send the message to the connected TcpServer.
stream.Write(data, 0, data.Length)
' Receive the TcpServer.response.
' Buffer to store the response bytes.
data = New [Byte](256) {}
If stream.CanRead Then
    Dim myReadBuffer(1024) As Byte
    Dim myCompleteMessage As System.Text.StringBuilder = New System.Text.StringBuilder
    Dim numberOfBytesRead As Integer = 0
    ' Incoming message may be larger than the buffer size.
    Do
        Try
            Threading.Thread.Sleep(100)
            numberOfBytesRead = stream.Read(myReadBuffer, 0, myReadBuffer.Length)
            myCompleteMessage.AppendFormat("{0}", System.Text.Encoding.ASCII.GetString(myReadBuffer, 0, numberOfBytesRead))
        Catch ex As Exception
            stream.Close()
            client.Close()
            Exit Sub
        End Try
    Loop While stream.DataAvailable
    ' Close everything.
    stream.Close()
    client.Close()
    Exit Sub
Else
    Exit Sub
End If
Smudge . . . you were close. Since there is no "Imports", you just have to use your classes explicitly.
So for example, to set the output on a videohub:
Code:
Dim clientPort as String = "9990"
Dim input as String = "1"
Dim output as String = "7"
Dim message as String = "VIDEO OUTPUT ROUTING:" & Environment.NewLine & output & " " & input & Environment.NewLine & Environment.NewLine
-Brian
TESN.US
thanks 3 users thanked tesn for this useful post.
stevespaw on 12/27/2018(UTC), Stavlin on 1/2/2019(UTC), osnyfv on 4/12/2022(UTC)
jthorup
#6 Posted : Tuesday, October 20, 2020 1:48:15 AM(UTC)
jthorup
I'm trying to create a script using the code mentioned in this thread.
I'm trying to send Telnet commands to a Vaddio Roboshot20 PTZ camera. I have successfully sent commands from command prompt and PowerShell, but I'm not having success in vMix.
I think that my issue might be that there is a username and password that you have to enter before you can throw commands at the camera.
This is what I've tried so far.
Dim clientIP as String = "192.168.3.101"
Dim clientPort as String = "23"
Dim message as String = "admin"
message = "password"
message = "camera preset recall 1"
I'm not much of a coder so my apologies for my noobiness.
pignonson
#7 Posted : Sunday, February 7, 2021 3:11:00 AM(UTC)
pignonson
Hi jthrup,
Did you find some solutions for your usecase?
I've the same situation as you. I am looking to send telnet commands from vmix. I don't have to fill username or password. Only a command like "page 1000: read" with an ip and a port.
It works fine with powershell. But, the script above doesn't work for me either.
Guest (4)
