Wave Plugin for Live Streaming
Hi, I plan to use Wave Plugin (Vocal Rider, SSL 4000). Will they work well?
Mainly for Leveling of Live audio.
If there any suggest, link me. Thanks
Joined: 8/5/2015(UTC) Posts: 51  Location: Germany Thanks: 12 times Was thanked: 4 time(s) in 4 post(s)
I'm using L2 and others (C1, etc.) without problems (inserted in the Master)
Knut
Joined: 5/14/2018(UTC) Posts: 114 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
Were using multiple plugins for one of our clients https://www.twitch.tv/encounterroleplay) Oneknob louder and PSE on every Vcall and Ozone 8 on our master. Before this Ive used Scheps omni channel, CLA2 and mastering plugins from waves. Some versions ago we had a memory leak issue which has since been solved resulting in almost a year of daily stable streaming. The main thing to consider is latency compensation. Most plugins are near-zero latency, but some have more. The ozone does 300ms in our settings. You can compensate audio being late in the External Output settings -> Audio delay. This one you can put a negative number as well.
 2 users thanked Vuurmannetje for this useful post.
rowby on 11/8/2018(UTC), Ario on 6/16/2019(UTC)
