kevev
#1 Posted : Wednesday, November 7, 2018 1:50:56 AM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
Is there a way to increase the size of the 4 replay monitors in the replay panel? They are at the top right and are way too small to be usable.
dasmedienatelier
#2 Posted : Wednesday, November 28, 2018 9:07:20 PM(UTC)
dasmedienatelier
If you have a second monitor you can select "Fullscreen" on the second one and set it to either "Multiview", or you if you want a custom size, you can set up a blank input and put the replay inputs into the multiviewer of this input (selecting size and position). Set the fullscreen display to this input and voila.
Knut
thanks 1 user thanked dasmedienatelier for this useful post.
Ario on 6/16/2019(UTC)
