Instant Replay
Increase size of replay monitor
Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
Is there a way to increase the size of the 4 replay monitors in the replay panel? They are at the top right and are way too small to be usable.
You have been a member since:: 8/5/2015(UTC) Posts: 51  Location: Germany Thanks: 12 times Was thanked: 4 time(s) in 4 post(s)
If you have a second monitor you can select "Fullscreen" on the second one and set it to either "Multiview", or you if you want a custom size, you can set up a blank input and put the replay inputs into the multiviewer of this input (selecting size and position). Set the fullscreen display to this input and voila.
Knut
 1 user thanked dasmedienatelier for this useful post.
Instant Replay
