Triggering Zoom Names of Virtual Sets
Joined: 10/9/2018(UTC) Posts: 28   Location: Leesburg AL Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Is there a way to set 2 triggers for a virtual set input to activate zoom name Close Up on transition in and then activate zoom name Full on transition out? I can only seem to trigger the zoom name if the input is live?
The goal is to have an image I have loaded in the background of the virtual set to zoom in about 10% in 10 seconds on a transition in, then reset to full screen when the input is transitioned away.
Maybe a Virtual set function that can be used like the General, Audio, Output/Input functions etc?
I also want to do this with a camera shot as well, but that is a side note.
Yes! SelectIndex is the command you're looking for
Guillaume
THANK YOU!!! I have been searching for this answer for weeks!
