Brian D.
#1 Posted : 7 years ago
Brian D.
Is there a way to set 2 triggers for a virtual set input to activate zoom name Close Up on transition in and then activate zoom name Full on transition out?
I can only seem to trigger the zoom name if the input is live?
The goal is to have an image I have loaded in the background of the virtual set to zoom in about 10% in 10 seconds on a transition in, then reset to full screen
when the input is transitioned away.
Maybe a Virtual set function that can be used like the General, Audio, Output/Input functions etc?
I also want to do this with a camera shot as well, but that is a side note.
#2 Posted : 7 years ago
Was thanked: 795 time(s) in 589 post(s)
Yes! SelectIndex is the command you're looking for
Guillaume
Brian D.
#3 Posted : 7 years ago
Brian D.
THANK YOU!!! I have been searching for this answer for weeks!
