joel05
#1 Posted : Friday, October 26, 2018 1:22:35 PM(UTC)
joel05
Canada
I'm thinking build a pc with all chosen components to run vmix. The goal is not going to cheap and not overkill.
I have a pc built for video and timelapse, so I have the GTX 1080 TI.
Do you think such card is overkill for Vmix, and if yes, what alternative (cost/quality) could be acceptable ?
RadekOlszakPl
#2 Posted : Sunday, October 28, 2018 8:46:33 AM(UTC)
RadekOlszakPl
But can vmix use more than 1 nvenc stream?
I think vmix can use only 1 nvenc accelerated stream. (rtmp output stream).
