Joined: 10/25/2018(UTC) Posts: 8  Location: Mont St Hilaire Thanks: 1 times
I'm thinking build a pc with all chosen components to run vmix. The goal is not going to cheap and not overkill. I have a pc built for video and timelapse, so I have the GTX 1080 TI.
Do you think such card is overkill for Vmix, and if yes, what alternative (cost/quality) could be acceptable ?
But can vmix use more than 1 nvenc stream? I think vmix can use only 1 nvenc accelerated stream. (rtmp output stream).
