BigApple
#1 Posted : Monday, October 15, 2018 3:56:08 PM(UTC)
BigApple
Would Vmix see all 8 inputs if I chain a IO 4k at the end of an Io 4K Plus.
Or at least could I make one unit useful for the upstream and the other for the downstream ? Like 4 cam in and 4 Aux Bus outputs through the other Io 4K ???
Thank you for your insights
SportsNetUSA.net
#2 Posted : Tuesday, October 16, 2018 4:52:23 AM(UTC)
SportsNetUSA.net
Yes, vMix should see all 8 inputs. I've connected a AJA IO XT and chained a Sonnet Echo Express/AJA Kona 3G and all the inputs were listed in vMix. Assuming you are using a laptop with Thunderbolt, doing an actual production with 8 inputs at 1080p/59.94 might be an issue.
thanks 1 user thanked SportsNetUSA.net for this useful post.
BigApple on 11/15/2018(UTC)
BigApple
#3 Posted : Thursday, November 15, 2018 2:55:31 AM(UTC)
BigApple
thank you it worked. like you said but after 6 inputs it dropped frames like crazy
azanisarri
#4 Posted : Saturday, December 22, 2018 3:06:05 AM(UTC)
azanisarri
Malaysia
How about if my laptop haved gtx1080 card and use setting 720 50p camera/vmix input...is there any issue? Thank You.
