Hello, how i can disable the task error on vmix? sometimes the stream of webcam go away and vmix show task error and block the camera, if i close task the camera auto reconnect by itself and work fine. how bypass?
Thank you everyone
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
Which error are you getting?
I don't think you can disable the error notification so you'd most likely be better of if you can find a way to remove the error in stead.
Hello, thank you for your answer. i get the error Presets_OpenInput, impossible connection. If camera is down get this task, if click close the stream of camera go up and reconnect by itself
Have you tried asking vMix to reset the connection? Right click on input > Reset
Yes, this solution work fine. My streaming it's 24/24, the video of camera will not be show until close the error task and click reset. if possible i need to disabilitate error task by vmix or close by browser url.
Thank you
