pagu
#1 Posted : Wednesday, October 3, 2018 8:39:46 PM(UTC)
pagu
Hello, how i can disable the task error on vmix?
sometimes the stream of webcam go away and vmix show task error and block the camera, if i close task the camera auto reconnect by itself and work fine.
how bypass?
Thank you everyone
Lennart
#2 Posted : Monday, October 8, 2018 12:10:33 PM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
Which error are you getting?
I don't think you can disable the error notification so you'd most likely be better of if you can find a way to remove the error in stead.
pagu
#3 Posted : Monday, October 8, 2018 5:55:39 PM(UTC)
pagu
Hello, thank you for your answer.
i get the error Presets_OpenInput, impossible connection.
If camera is down get this task, if click close the stream of camera go up and reconnect by itself
ask
#4 Posted : Monday, October 8, 2018 5:58:45 PM(UTC)
ask
Have you tried asking vMix to reset the connection? Right click on input > Reset
pagu
#5 Posted : Thursday, October 11, 2018 9:01:02 PM(UTC)
pagu
Yes, this solution work fine.
My streaming it's 24/24, the video of camera will not be show until close the error task and click reset.
if possible i need to disabilitate error task by vmix or close by browser url.
Thank you
Similar Topics
disable vmix task error or bypass openinput (Feature Requests)
by pagu 1/21/2019 7:05:23 PM(UTC)
