Feature Requests
mixing level control for layers in multiview
Multiview could be a lot more flexible if we could have control of the mixing of the layers.
This would be like the alpha control on the overlays. It would allow someone to have a image with an alpha channel allowing it to be keyed, but then made semi-transparent in some cases.
Key invert would also be handy.
What is the use case for that. I don't get it.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Lots of reasons - See my post on drop shadows on the main discussion.
IF we had opacity and shortcuts to them - we may get to the point we could have layers fade in and out in the "MultiView" Now we are really talking about power control.
Steve
 2 users thanked stevespaw for this useful post.
mavik wrote:What is the use case for that. I don't get it. The ability to have a single reference logo with a complex alpha. Use it fully opaque in some shots. That's alpha channel keyed, and fully mixed into view. Use it semi-transparent in other places. That's alpha channel keyed, and partially mixed into view. We already have such capability in the overlays. It's just a question of allowing it in the multiviews layers. That would allow the multiview composites to be more sophisticated, without requiring a ton of prep work in Photoshop, and many more elements in the project.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
+1 to opacity and an invert function. These are bread and butter tools making a lot of other creative uses easily possible.
Perhaps a soft edge function on the crop.
 1 user thanked Peter B for this useful post.
Thanks: 2 times Was thanked: 10 time(s) in 9 post(s)
+1 huge benefit. I use 3 keys for one graphic with 3 separate parts, because I can't transition in a multiview, otherwise I'd use a multiview and transition, freeing up most of my keyers for other use.
Feature Requests
