rowby
#1 Posted : Wednesday, September 12, 2018 8:40:02 PM(UTC)
rowby
Hello Everybody,
I'm using a Behringer U-Phoria UM2 On a Windows 7 machine.
By default it only records on the left side. I am trying to find a setting for the input to force it to record on both the left and right side -- in Mono.
Is there a setting I'm missing?
Ideally I would prefer to make this setting natively in my Windows computer. According to Mr. Google, Windows 10 allows me to force stereo recording to mono. But I don't see this feature on my Windows 7 machine.
Any suggestions, perhaps by someone who is using the UM2 for both channels on their Windows 7 vMix installation? Or a setting in vMix forcing mono to an auduio input?
Rowby
TFMG
#2 Posted : Thursday, September 13, 2018 1:11:04 AM(UTC)
TFMG
Hi Rowby,
Check out the Channel Matrix in the Audio Settings for your input - I think you'll find what you're after in there:
https://www.vmix.com/hel...x.htm?AudioSettings.html
thanks 1 user thanked TFMG for this useful post.
rowby on 9/13/2018(UTC)
rowby
#3 Posted : Thursday, September 13, 2018 10:33:37 AM(UTC)
rowby
Thanks TFMG!
That did the trick.
I went in and checked all of the matrix. Sounds good and getting both tracks.
I will double check the documentation, but I guess it doesn't "hurt" to check all of the boxes.
I appreciate your quick reply. I had been trying everything -- virtual cables, voicemeeter, etc. Nothing seemed to do the trick.
So your forum post came in just in time!
Rowby
rowby attached the following image(s):
