Forcing Vmix to record in mono
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Hello Everybody,
I'm using a Behringer U-Phoria UM2 On a Windows 7 machine.
By default it only records on the left side. I am trying to find a setting for the input to force it to record on both the left and right side -- in Mono.
Is there a setting I'm missing?
Ideally I would prefer to make this setting natively in my Windows computer. According to Mr. Google, Windows 10 allows me to force stereo recording to mono. But I don't see this feature on my Windows 7 machine.
Any suggestions, perhaps by someone who is using the UM2 for both channels on their Windows 7 vMix installation? Or a setting in vMix forcing mono to an auduio input?
Rowby
Joined: 2/18/2018(UTC) Posts: 39  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
 1 user thanked TFMG for this useful post.
Thanks TFMG! That did the trick. I went in and checked all of the matrix. Sounds good and getting both tracks. I will double check the documentation, but I guess it doesn't "hurt" to check all of the boxes. I appreciate your quick reply. I had been trying everything -- virtual cables, voicemeeter, etc. Nothing seemed to do the trick. So your forum post came in just in time! Rowby rowby attached the following image(s):  audio-matrix.jpg (207kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
