I can not hear the Web Browser audio
I set a web browser url input as an multi view to an another input (means my overlay). This is a stream alert via Streamelements application. If for example an user follow my channel, then this url get active in my stream (so it is visible), but I can not hear any audio. Means I do not get that they followed my channel. Only in my chat I can read this information.
What should I change to be able to hear the audio?
Multiview or Overlay?
Not the same thing
@ kozaka
Does the Web Browser Input have audible audio in vMix otherwise? I am not sure I completely understand your workflow as described. As a Multiview Input Overlay, the audio should play. As a DSK Overlay (buttons 1,2,3 or 4) it will not unless you configure the audio to be ON in those situations (Triggers will work for this).
