kozaka
#1 Posted : Friday, August 31, 2018 2:07:56 PM(UTC)
kozaka
I set a web browser url input as an multi view to an another input (means my overlay). This is a stream alert via Streamelements application. If for example an user follow my channel, then this url get active in my stream (so it is visible), but I can not hear any audio. Means I do not get that they followed my channel. Only in my chat I can read this information.
What should I change to be able to hear the audio?
#2 Posted : Saturday, September 8, 2018 2:32:44 AM(UTC)
Multiview or Overlay?
Not the same thing
#3 Posted : Saturday, September 8, 2018 7:44:41 AM(UTC)
@ kozaka
Does the Web Browser Input have audible audio in vMix otherwise?
I am not sure I completely understand your workflow as described.
As a Multiview Input Overlay, the audio should play.
As a DSK Overlay (buttons 1,2,3 or 4) it will not unless you configure the audio to be ON in those situations (Triggers will work for this).
