michaelrb
#1 Posted : Saturday, August 25, 2018 3:24:57 PM(UTC)
michaelrb
Can you have multiple general vmix settings remembered by VMix. Each time you change a setting, the system stops and restarts. Anyway to save the settings?
#2 Posted : Sunday, August 26, 2018 2:30:12 AM(UTC)
As the name implies general settings are "global" settings!
What's the problem having to close and reopen vMix from time to time in case you need to change something for a specific session?
Anyway the need to reopen with new settings is mostly due to the need to reintialize the connection between vMix and the capture devices or the graphic card so having presets would not change anything in the process...
Settings are always saved by default. Last changes are saved for next sessions
Guillaume
michaelrb
#3 Posted : Sunday, August 26, 2018 8:47:57 AM(UTC)
michaelrb
DWAM...I didn't say I had a problem, I just asked a question. Manners? Thanks you for your needless response.
