Multiple vmix general settings
Joined: 7/14/2017(UTC) Posts: 100   Location: South Florida Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Can you have multiple general vmix settings remembered by VMix. Each time you change a setting, the system stops and restarts. Anyway to save the settings?
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
As the name implies general settings are "global" settings! What's the problem having to close and reopen vMix from time to time in case you need to change something for a specific session? Anyway the need to reopen with new settings is mostly due to the need to reintialize the connection between vMix and the capture devices or the graphic card so having presets would not change anything in the process...
Settings are always saved by default. Last changes are saved for next sessions
Guillaume
DWAM...I didn't say I had a problem, I just asked a question. Manners? Thanks you for your needless response.
