How to make the text go across the screen using a custom ticker
Rank:: Newbie
Hey everyone i'm new to vMix and i have created my own news ticker with a live logo and logo and i have got everything working apart of from the ticker as i have added text but when i click play it the text doesn't move can anybody help.
If the text aint moving accros it aint a ticker ;-)
No seriously , how are we supposed to know what the problem is based on "i have added text but when i click play it the text doesn't move"
If it is not working then it is not coded correctly , have you checked as example how the existig tickers are working (how the xaml is coded)?
Rank:: Newbie
doggy wrote:If the text aint moving accros it aint a ticker ;-)
If it is not working then it is not coded correctly , have you checked as example how the existig tickers are working (how the xaml is coded)? I have looked at the other tickers to see how they have programmed but i can't see the exact info i'm looking for
It's in the "storyboard" part
I still don't understand how one can make something custom if one doesn't know how it works. And why not modify an existing one rather than create one to start with ?
Rank:: Newbie
Do you mean the title editor and i wanted to make my own sorry for the confusion
you can't create a ticker with the current editor , you need to manually code/modify the XAML file of the title or use Blend to visually program stuff in your title. The title editor is for static stuff , not animations ( ticker is a animation where a textblock that contains text moves accross
Understand you want to make your own , but then you need to know how to proces it first. There are various ways to code a ticker in XAML (Google can help you out on that)
Rank:: Newbie
okay got ya i thank you for your help
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
in title editor use... ticker...
Barney Box Lane wrote:in title editor use... ticker... Can you elaborte on this please as i don't see it !
i use tickerHD3.xaml and it scrolls text across at a set duration
Barney Box Lane wrote:i use tickerHD3.xaml and it scrolls text across at a set duration of course using an existing ticker and combine (lyer) it with added graphics etc but thats not what OP was asking . Furthermore "in title editor use... ticker.." is not possible as as far as my english is concerned it would have been "as input use a existing ticker" ;-)
