Joined: 8/15/2018(UTC) Posts: 1 Location: Cote d'ivoire
I'm trying to configure vmix for external output with declkink equipment but I encounter an error. selected video format is not supported by this device: bmdmodpal access denied (Exception HRESULT : 0x80070005 (E_ACCESSDENIED)) NEED HELP
need more info. Project settings, resolution you're trying to set up, more details on your setup.
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
CIELTV wrote:I'm trying to configure vmix for external output with declkink equipment but I encounter an error. selected video format is not supported by this device: bmdmodpal access denied (Exception HRESULT : 0x80070005 (E_ACCESSDENIED)) NEED HELP
Under External, try to select a different resolution and/or frame rate. It has to match what the actual card can do. Check the website out and pick your card to view its' specs: https://www.blackmagicdesign.com/products/decklink/techspecs/W-DLK-34For example, the Duo 2 can do the following: Code:720p50, 720p59.94, 720p60
1080p23.98, 1080p24, 1080p25, 1080p29.97, 1080p30, 1080p50, 1080p59, 1080p59.94, 1080p60
1080PsF23.98, 1080PsF24, 1080PsF25, 1080PsF29.97, 1080PsF30
1080i50, 1080i59.94, 1080i60
