CIELTV
#1 Posted : Wednesday, August 15, 2018 10:08:00 AM(UTC)
CIELTV
I'm trying to configure vmix for external output with declkink equipment
but I encounter an error.
selected video format is not supported by this device: bmdmodpal access denied
(Exception HRESULT : 0x80070005 (E_ACCESSDENIED))
NEED HELP
spencerm24
#2 Posted : Wednesday, August 15, 2018 1:48:50 PM(UTC)
spencerm24
need more info. Project settings, resolution you're trying to set up, more details on your setup.
niemi
#3 Posted : Saturday, August 18, 2018 1:39:15 PM(UTC)
niemi
Was thanked: 18 time(s) in 15 post(s)
NEED HELP
Under External, try to select a different resolution and/or frame rate.
It has to match what the actual card can do. Check the website out and pick your card to view its' specs:
https://www.blackmagicdesign.com/products/decklink/techspecs/W-DLK-34
For example, the Duo 2 can do the following:
Code:
720p50, 720p59.94, 720p60
1080p23.98, 1080p24, 1080p25, 1080p29.97, 1080p30, 1080p50, 1080p59, 1080p59.94, 1080p60
1080PsF23.98, 1080PsF24, 1080PsF25, 1080PsF29.97, 1080PsF30
1080i50, 1080i59.94, 1080i60
