wwdv
#1 Posted : Tuesday, December 3, 2013 8:26:33 AM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
WME9 can capture the vMix video output, but vMix doesn't offer a audio capture device that WME can use.
I know that I can use Adove flash, but I need WME in my case (my church stream provider has no flash support).
I am using the Viewcast Osprey 440 and WME can only capture 1 stereo audio input at the same time.
I need 2 stereo audio inputs so I have to use vMix as the audio capture source.
It would be very handy if vMix had a virtual audio output that also can act as a playback device in Windows.
Can someone explain me why WME doesn't see the vMix audio output device and why FME does?
Can I use some 3th party software as a converter between vMix and WME?
EDIT: vMix audio is not available in WinXP, and WME doesn't work in Win7 (0x80070005 The specified module could not be found)
