Feature Requests
vMix audio capture device for WME
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
WME9 can capture the vMix video output, but vMix doesn't offer a audio capture device that WME can use. I know that I can use Adove flash, but I need WME in my case (my church stream provider has no flash support).
I am using the Viewcast Osprey 440 and WME can only capture 1 stereo audio input at the same time. I need 2 stereo audio inputs so I have to use vMix as the audio capture source. It would be very handy if vMix had a virtual audio output that also can act as a playback device in Windows.
Can someone explain me why WME doesn't see the vMix audio output device and why FME does? Can I use some 3th party software as a converter between vMix and WME?
EDIT: vMix audio is not available in WinXP, and WME doesn't work in Win7 (0x80070005 The specified module could not be found)
Feature Requests
