Key/Fill input no feathering
Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
If I make a png with feathered edges and try to use it as a key/fill in the colour key menu the feathering disapears and I get a hard edged shape. Am I doing something wrong or is this a quirk? NHT attached the following image(s):  no feathering.jpg (122kb) downloaded 6 time(s).You cannot view/download attachments. Try to login or register.
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
Are you applying the mask? It must be assigned in the source item. Here's what I just created.
Thanks for the reply, I think I'm beginning to lose it. I'm sure this used to work, I've tried creating the png on a different machine and tried a different install of vMix on another machine, same effect! NHT attached the following image(s):  no feathering2.jpg (255kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Ignore me, I had a senior moment, thanks for the reply MJ.
In case anyone does the same as me and ends up reading this, I had turned my background colour in p/shop to black so didn't realize I was outputting the image with transparency when vMix is look for a white over black image.
If you pull a white over transparent image in vMix it looks black and white.
I'm such a dumb a...
