NHT
#1 Posted : Wednesday, July 11, 2018 9:16:11 AM(UTC)
NHT
If I make a png with feathered edges and try to use it as a key/fill in the colour key menu the feathering disapears and I get a hard edged shape.
Am I doing something wrong or is this a quirk?
NHT attached the following image(s):
no feathering.jpg (122kb) downloaded 6 time(s).
mjgraves
#2 Posted : Wednesday, July 11, 2018 11:09:37 AM(UTC)
mjgraves
Are you applying the mask? It must be assigned in the source item. Here's what I just created.
NHT on 7/11/2018(UTC)
NHT
#3 Posted : Wednesday, July 11, 2018 11:52:47 AM(UTC)
NHT
Thanks for the reply, I think I'm beginning to lose it.
I'm sure this used to work, I've tried creating the png on a different machine and tried a different install of vMix on another machine, same effect!
no feathering2.jpg (255kb) downloaded 2 time(s).
NHT
#4 Posted : Wednesday, July 11, 2018 12:03:30 PM(UTC)
NHT
Ignore me, I had a senior moment, thanks for the reply MJ.
In case anyone does the same as me and ends up reading this, I had turned my background colour in p/shop to black so didn't realize I was outputting the image with transparency when vMix is look for a white over black image.
If you pull a white over transparent image in vMix it looks black and white.
I'm such a dumb a...
