Dear V Mix
First thanks for a very very good software.
I am working on a big Sports tv station in Denmark and we are trying to use Vmix more and more on our smaller productions.
I have just bought a super nice usb soundmixer Zoom Livetrack L-12 and I will like to use it as a usb audio interface for V mix. This USB mixer is very good due to it have 5 mix-minus output, what we need if when we have more than 2 persons in the studio and they all want to have their own mix minus, and if they want to hear them self without a delay.
But when I try to add a sound input, V Mix can see it, but when I click ok it come op with this erorr.
"Unable to initialize Asio driver: Studio 192 - ASIO,BASS_ERROR_DRIVER"
I have install the driver to the Zoom livertrack unit.
Please help
Sylvest
Have you tried uninstalling, then reinstalling the driver? If that has been done, have you tried using ASIO 4 All? http://www.asio4all.org/
Joined: 3/7/2019(UTC) Posts: 9  Location: Medellin Thanks: 1 times
Please help
Sylvest
Have you resolved it?
Hi, got my L-12 today and had the same Problems. Tried a asio4all driver but never get any signal input in Vmix. Any ideas? Thanks Michael
ASIO4all won't always work, it's just a hack with wdm drivers.
Are you sure it's not set to usb host instead of audio interface with the switch at the back of the unit?
Thanks Ittaidv. The switch is and was in the Right Position. Andy other Idea?
Any update on this?
I have the exact same issue. I've tried on two different Windows 10 machines. I know the ASIO driver works correctly as i can return Audio to the Livetrak L-12 simply by using the Test tone in the Windows sound settings.
I had the same Problem and managed to get it to work now. I can't specify what the final solution was, but i took the following steps: - install asio4all / http://www.asio4all.org/- Install latest Drivers - Firmware Update to latest Version - Factory Reset - Setting the Sample Rate to 48kHz - Setting Class Compliant Mode to "off" - Setting the Mode to "Audio Interface" - IMPORTANT: Connect and power on the Livetrak L-12 before opening vMix. If vMix is open before connecting, the same Error will appear for me. The other way around it works just fine. //EDIT: Uninstalled asio4all and nothing worked anymore. Reinstalled asio4all and it's back to working, so it seems like this was the key-factor for me //EDIT2: Changing the USB-Cable to a higher Quality one also helped in getting the right connection
Rank:: Member
Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
Working with no issues with stock/decent USB cable and stock drivers from zoom (no asio4all), can operate all inputs/outputs of the L12
Thanks: 187 times Was thanked: 20 time(s) in 17 post(s)
Regarding the L-8 (not the L-12):
My L-8 just arrived; installed the Windows driver, selected Asio in vMix (v23 in my case), and then you're able to select the individual channels as separate audio inputs in vMix. Just what I needed.
Thanks everyone for your help.
Boa tarde. NO meu caso estava funcionando e deu o mesmo erro após uma atualização do Windows; Isso é comum acontecer; sabem como resolver sem reverter a instalação do Windows? Originally Posted by: Peter Sylvest  Dear V Mix
Please help
Sylvest
