Peter Sylvest
#1 Posted : Friday, July 6, 2018 7:28:17 AM(UTC)
Peter Sylvest
Dear V Mix
First thanks for a very very good software.
I am working on a big Sports tv station in Denmark and we are trying to use Vmix more and more on our smaller productions.
I have just bought a super nice usb soundmixer Zoom Livetrack L-12 and I will like to use it as a usb audio interface for V mix.
This USB mixer is very good due to it have 5 mix-minus output, what we need if when we have more than 2 persons in the studio and they all want to have their own mix minus, and if they want to hear them self without a delay.
But when I try to add a sound input, V Mix can see it, but when I click ok it come op with this erorr.
"Unable to initialize Asio driver: Studio 192 - ASIO,BASS_ERROR_DRIVER"
I have install the driver to the Zoom livertrack unit.
Please help
Sylvest
SportsNetUSA.net
#2 Posted : Monday, July 9, 2018 8:58:57 PM(UTC)
SportsNetUSA.net
Have you tried uninstalling, then reinstalling the driver?
If that has been done, have you tried using ASIO 4 All?
http://www.asio4all.org/
manuelgomezo
#3 Posted : Friday, April 5, 2019 1:55:01 PM(UTC)
manuelgomezo
Colombia
Originally Posted by: Peter Sylvest Go to Quoted Post
Dear V Mix
Please help
Sylvest
Have you resolved it?
PogoBerlin
#4 Posted : Tuesday, January 7, 2020 5:45:06 AM(UTC)
PogoBerlin
Germany
Hi, got my L-12 today and had the same Problems. Tried a asio4all driver but never get any signal input in Vmix. Any ideas?
Michael
Ittaidv
#5 Posted : Saturday, January 11, 2020 9:33:19 AM(UTC)
Ittaidv
ASIO4all won't always work, it's just a hack with wdm drivers.
Are you sure it's not set to usb host instead of audio interface with the switch at the back of the unit?
PogoBerlin
#6 Posted : Tuesday, January 14, 2020 1:10:52 AM(UTC)
PogoBerlin
Germany
Thanks Ittaidv. The switch is and was in the Right Position. Andy other Idea?
Jof
#7 Posted : Sunday, July 5, 2020 12:54:10 AM(UTC)
Jof
Any update on this?
I have the exact same issue. I've tried on two different Windows 10 machines. I know the ASIO driver works correctly as i can return Audio to the Livetrak L-12 simply by using the Test tone in the Windows sound settings.
slxxi
#8 Posted : Friday, November 20, 2020 7:06:56 AM(UTC)
slxxi
I had the same Problem and managed to get it to work now.
I can't specify what the final solution was, but i took the following steps:
- install asio4all / http://www.asio4all.org/
- Install latest Drivers
- Firmware Update to latest Version
- Factory Reset
- Setting the Sample Rate to 48kHz
- Setting Class Compliant Mode to "off"
- Setting the Mode to "Audio Interface"
- IMPORTANT: Connect and power on the Livetrak L-12 before opening vMix. If vMix is open before connecting, the same Error will appear for me. The other way around it works just fine.
//EDIT: Uninstalled asio4all and nothing worked anymore. Reinstalled asio4all and it's back to working, so it seems like this was the key-factor for me
//EDIT2: Changing the USB-Cable to a higher Quality one also helped in getting the right connection
lainol
#9 Posted : Friday, December 25, 2020 1:11:10 AM(UTC)
lainol
Working with no issues with stock/decent USB cable and stock drivers from zoom (no asio4all), can operate all inputs/outputs of the L12
Ario
#10 Posted : Friday, March 26, 2021 9:19:31 PM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
Regarding the L-8 (not the L-12):
My L-8 just arrived; installed the Windows driver, selected Asio in vMix (v23 in my case),
and then you're able to select the individual channels as separate audio inputs in vMix. Just what I needed.
Thanks everyone for your help.
milton.cee
#11 Posted: : Saturday, November 15, 2025 3:17:04 AM(UTC)
milton.cee
Brazil
Boa tarde. NO meu caso estava funcionando e deu o mesmo erro após uma atualização do Windows; Isso é comum acontecer; sabem como resolver sem reverter a instalação do Windows?
Dear V Mix
Please help
Sylvest
