spencerm24
#1 Posted : Sunday, June 17, 2018 2:02:25 AM(UTC)
spencerm24
Fairly high end system, had 400 dropped frames over 4.5 hour broadcast tonight, all of them were "due to source framerate" what does this mean? What can I do to better improve things?
System:
i7 8700k
16GB RAM
GTX 1060
250GB SSD Boot
500GB SSD Record
1TB NVME Replay drive.
2 cams, with replay, 2 Streams at 720p 2.5mbps each (hardware encoder, I think, see my next post related to this...basically only get two hardware encoders, but I thought selecting "same quality as stream 1" doesn't add another load to the gpu, instead sends the same encode to different places?)
melody
#2 Posted : Thursday, June 21, 2018 7:53:56 AM(UTC)
Rank: Guest
Groups:
hi spencerm24,
how do you connect your cams to pc? you must be sure from good cables to hardware bandwidth, everything is connected and installed correctly...
cheers,
melody
