Dropped frames due to source framerate??
Fairly high end system, had 400 dropped frames over 4.5 hour broadcast tonight, all of them were "due to source framerate" what does this mean? What can I do to better improve things?
System: i7 8700k 16GB RAM GTX 1060 250GB SSD Boot 500GB SSD Record 1TB NVME Replay drive.
2 cams, with replay, 2 Streams at 720p 2.5mbps each (hardware encoder, I think, see my next post related to this...basically only get two hardware encoders, but I thought selecting "same quality as stream 1" doesn't add another load to the gpu, instead sends the same encode to different places?)
Rank: Guest
Groups: Guests
hi spencerm24,
how do you connect your cams to pc? you must be sure from good cables to hardware bandwidth, everything is connected and installed correctly...
cheers,
melody
