Three streams max from vmix?
Thanks: 16 times Was thanked: 4 time(s) in 3 post(s)
At one time I thought we could do more than three streams at a time. Am I mistaken?
There are three possible destinations, but it appears to me that each destination only allows one stream.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
No, it's only 3 streams to 1 destination on each stream. EliYahu wrote:At one time I thought we could do more than three streams at a time. Am I mistaken?
 1 user thanked desmar for this useful post.
Thanks, I'm not clear on what you mean. "No" as in it doesn't, or "no" it does allow more than three?
it was never more than 3 streams. EliYahu wrote:Thanks, I'm not clear on what you mean. "No" as in it doesn't, or "no" it does allow more than three?
@ EliYahu
It has always been the same Output. At one time it was either 3 different bitrates to one destination or same bitrate to 3 destinations, but that was quite a while ago and now it is any combination of the above, that is 3 destinations at three different bitrates with different start and stop times. There is a feature request to allow for different content to be streamed to the different destinations, so if that is what you are looking for I would suggest you add your support there.
