EliYahu
#1 Posted : Wednesday, June 13, 2018 8:26:42 PM(UTC)
EliYahu
At one time I thought we could do more than three streams at a time. Am I mistaken?
There are three possible destinations, but it appears to me that each destination only allows one stream.
desmar
#2 Posted : Wednesday, June 13, 2018 8:36:32 PM(UTC)
desmar
Canada
No, it's only 3 streams to 1 destination on each stream.
thanks 1 user thanked desmar for this useful post.
EliYahu on 6/13/2018(UTC)
EliYahu
#3 Posted : Wednesday, June 13, 2018 8:39:35 PM(UTC)
EliYahu
Thanks, I'm not clear on what you mean. "No" as in it doesn't, or "no" it does allow more than three?
desmar
#4 Posted : Wednesday, June 13, 2018 8:51:23 PM(UTC)
desmar
Canada
it was never more than 3 streams.
EliYahu on 6/14/2018(UTC)
#5 Posted : Wednesday, June 13, 2018 9:13:33 PM(UTC)
@ EliYahu
It has always been the same Output.
At one time it was either 3 different bitrates to one destination or same bitrate to 3 destinations, but that was quite a while ago and now it is any combination of the above, that is 3 destinations at three different bitrates with different start and stop times.
There is a feature request to allow for different content to be streamed to the different destinations, so if that is what you are looking for I would suggest you add your support there.
