This is a different one....Stream isn't showing output video, bars instead
This is one I have no idea where to even start looking, but tested this to Youtube, private Ustream account, and facebook. My audio is my program/output audio mix, but the video is showing Bars (I don't even have bars as an input on this preset) The stream starts and stops on the youtube/Ustream interface when I start/stop the stream in vMix, but I only see bars.
Isn't this a feature some have requested? stream a different source? How did I even do that?
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
If you go to Settings - Outputs/NDI, what's selected as Output next to number 1? Normally this should be "Output". Maybe there's something else selected?
Kind regards, Rudy
Its not the external thats messed up, its the main output streamed. as far as I thought, we couldn't change the source of the stream, it was always set to "output"
Was thanked: 8 time(s) in 7 post(s)
I am having this same issue. Happened on a previous version of vmix and is happening on 23.0.0.65. External 1 is set to output but the stream is just rendering color bars. NDI output is correct but any feed sent over RTMP has issues.
