spencerm24
#1 Posted : Tuesday, June 12, 2018 1:00:21 PM(UTC)
spencerm24
This is one I have no idea where to even start looking, but tested this to Youtube, private Ustream account, and facebook. My audio is my program/output audio mix, but the video is showing Bars (I don't even have bars as an input on this preset) The stream starts and stops on the youtube/Ustream interface when I start/stop the stream in vMix, but I only see bars.
Isn't this a feature some have requested? stream a different source? How did I even do that?
#2 Posted : Friday, June 15, 2018 12:50:50 PM(UTC)
Check how to use EXTERNAL out (vMix virtual devices) for this use case and don't forget to activate the EXTERNAL button
https://www.vmix.com/help21/ExternalOutput1.html
Guillaume
rudyengels
#3 Posted : Saturday, June 16, 2018 3:27:36 PM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
If you go to Settings - Outputs/NDI, what's selected as Output next to number 1? Normally this should be "Output". Maybe there's something else selected?
Kind regards,
Rudy
spencerm24
#4 Posted : Sunday, June 17, 2018 2:32:31 AM(UTC)
spencerm24
Guillaume
Its not the external thats messed up, its the main output streamed. as far as I thought, we couldn't change the source of the stream, it was always set to "output"
djevo1
#5 Posted : Tuesday, October 13, 2020 8:44:47 AM(UTC)
djevo1
Was thanked: 8 time(s) in 7 post(s)
I am having this same issue. Happened on a previous version of vmix and is happening on 23.0.0.65. External 1 is set to output but the stream is just rendering color bars. NDI output is correct but any feed sent over RTMP has issues.
