Brian E. Conklin
#1 Posted : Monday, June 11, 2018 11:24:40 AM(UTC)
Brian E. Conklin
Hello, we recently started using data sources for our titles and it is great! A great addition to vMix would be to make image inputs data source aware as well. We use a virtual monitor on our virtual set and it would be great to be able to change the file path/URL for each week's images in a spreadsheet instead of manually changing them in the vMix image input.
Brian E. Conklin
Cell Life Church
https://www.celllifechurch.tv
#2 Posted : Monday, June 11, 2018 11:48:49 AM(UTC)
one already can. see help
#3 Posted : Monday, June 11, 2018 12:27:02 PM(UTC)
Yes as Doggy said it's already supported. I use it all the time to make dynamic titles. Just use the path to the images in a field
Guillaume
Brian E. Conklin
#4 Posted : Monday, June 11, 2018 12:57:31 PM(UTC)
Brian E. Conklin
I'm not talking about images in titles. Yes, those are supported. I am talking about image inputs. I do not see any option for data sources for them like in titles.
#5 Posted : Monday, June 11, 2018 1:15:47 PM(UTC)
have a title input that holds a full screen image linked to your datasource
have that "title" as input for your virtual monitor
Brian E. Conklin on 6/11/2018(UTC)
Brian E. Conklin
#6 Posted : Monday, June 11, 2018 1:29:12 PM(UTC)
Brian E. Conklin
Thanks. That may just work. I'll give it a whirl. It would be cleaner to have image inputs data source aware though.
Slaver
#7 Posted : Wednesday, June 13, 2018 8:16:01 AM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
i just have a question to those inputs you guys were talking about in this thread above.
I have the following situation:
We change from Livestream Studio to vMix right now on over 40 livestream-systems. In Livestream Studio we were able to set image columns in the data sources. I try my best but cannot find any similar solution in vMix.
Example:
In Handball we have a scoreboard (Gametime, Teamnames, Score) which is controlled by an external csv-File. When there is a 2 minute penalty against a player, we just set the image path in the csv-File and it shows up the graphic under the scoreboard. When the penalty is over, the graphic disappears by deleting the path out of the csv. Please have a look at the file attached.
Thank you so much for helping!!
File Attachment(s):
#8 Posted : Wednesday, June 13, 2018 8:38:01 AM(UTC)
JMO
instead of deleting the image path why not replace it with a 'blank image' path ?
Other options have been discussed in ths forum by means of title codebehind responding to values or simply coloring rectangles by colorcodes etc
Slaver on 6/14/2018(UTC)
Slaver
#9 Posted : Thursday, June 14, 2018 3:09:22 AM(UTC)
Slaver
Thank you doggy.
I got it work now after thinking about your and the other posts here.
video-live-pro
#10 Posted : Wednesday, October 24, 2018 8:22:28 PM(UTC)
video-live-pro
Guillaume
I can not figure out how to make dynamic photos with a sheet of excel I did not find any toutorial about it, can you tell me how it's done?
thank you
#11 Posted : Wednesday, October 24, 2018 10:44:54 PM(UTC)
timbrian on 12/12/2018(UTC)
