Joined: 6/19/2017(UTC) Posts: 6  Location: Richland, WA, USA Thanks: 2 times
Hello, we recently started using data sources for our titles and it is great! A great addition to vMix would be to make image inputs data source aware as well. We use a virtual monitor on our virtual set and it would be great to be able to change the file path/URL for each week's images in a spreadsheet instead of manually changing them in the vMix image input. Brian E. Conklin Cell Life Church https://www.celllifechurch.tv
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
one already can. see help
Yes as Doggy said it's already supported. I use it all the time to make dynamic titles. Just use the path to the images in a field
Guillaume
I'm not talking about images in titles. Yes, those are supported. I am talking about image inputs. I do not see any option for data sources for them like in titles.
have a title input that holds a full screen image linked to your datasource have that "title" as input for your virtual monitor
doggy wrote:have a title input that holds a full screen image linked to your datasource have that "title" as input for your virtual monitor Thanks. That may just work. I'll give it a whirl. It would be cleaner to have image inputs data source aware though.
Thanks: 27 times Was thanked: 8 time(s) in 8 post(s)
Hello, i just have a question to those inputs you guys were talking about in this thread above. I have the following situation: We change from Livestream Studio to vMix right now on over 40 livestream-systems. In Livestream Studio we were able to set image columns in the data sources. I try my best but cannot find any similar solution in vMix. Example: In Handball we have a scoreboard (Gametime, Teamnames, Score) which is controlled by an external csv-File. When there is a 2 minute penalty against a player, we just set the image path in the csv-File and it shows up the graphic under the scoreboard. When the penalty is over, the graphic disappears by deleting the path out of the csv. Please have a look at the file attached. Thank you so much for helping!! File Attachment(s):  scoreboardwithpenalties.png (3,093kb) downloaded 41 time(s).You cannot view/download attachments. Try to login or register.
JMO
instead of deleting the image path why not replace it with a 'blank image' path ?
Other options have been discussed in ths forum by means of title codebehind responding to values or simply coloring rectangles by colorcodes etc
Thank you doggy.
I got it work now after thinking about your and the other posts here.
Originally Posted by: DWAM  Yes as Doggy said it's already supported. I use it all the time to make dynamic titles. Just use the path to the images in a field
Guillaume I can not figure out how to make dynamic photos with a sheet of excel I did not find any toutorial about it, can you tell me how it's done? thank you
